Import of Interbus Descriptions Files " *.xml " is not possible . No ST- Line Modules avaible. PLC Next Engineer 2020.0 LTS
Hello ,
i´m trying to move an existing PCWorx Project ( RFC 4.30 ) to PLCNext Engineer.
i Cannot find the ST- Module Series in the Interbus libraries.
There are some third part Interbus members, Wago INterbus BK & Festo Valves.
I have the description Files from the customer which are working in PCworx (*.xml) .
But i cannot find a way to import them into PLCNext Engineer .
At the Import function there is only a fdcml Import possible .
Also a GSDML Import doesn´t work ( *.xml)
( Please rename the PDF File into Zip )
Thanks for the support and Best regards Ronald Messerer
Hi Ronald,
I guess that you are using an AXC F 2152 with the AXC F XT IB (2403018) ?
Unfortunately, PLCnext Engineer does not currently provide the feature that you want.
This article from a Community member provides one way of configuring the Interbus network via that extension module:
https://www.plcnext-community.net/en/hn-makers-blog/417-using-the-axc-f-2152-with-axc-f-xt-ib-module-to-integrate-interbus-modules-with-auto-interbus-reading.html
I hope this answers your question.
~ Martin.
Hello Martin,
you´re link is a nice description how to Autoread the Interbus.
But i want to import the attached Interbus description files which are working under the "old" PCworx .
Under PLCNext Engineer im not able to import them .
Best regards Ronald
Hi Ronald,
My understanding is that this feature is not currently planned for PLCnext Engineer.
For your reference, this issue is discussed in our (internal) Tech Guide - ticket number 00128072, and you should be able to add comments or questions to that ticket if you want.
Regards,
Martin.
