Error instalation nodes for modbus or OPC-UA
Recently I have been trying to install new nodes on node-red and usually give me this error, can someone help me solve it? I have very few things installed in the PLC and I find it strange to be out of space, thank you.
What is the result of the
df
command?If the Use% of the filesytem mounted on
/media/rfs/rw
is close to 100, then the memory is full.You can check the largest files using something like this command:
Hope this helps.
~ Martin.
