Function/Function block in structured text
Hello, I saw some material on creating Functions/Function blocks and its usage in LD code. However, I cannot find anything in structured text. I have a basic function that I would like to use in structured text.
When I pull the function in my main program, I do see the below code
Can you please provide an example on how to use the above function in structured text.
Thanks!
  • Hello,
    when you drag the function into the editor you will get a template of that function. You have to replace the placeholders with variables, e.g.
    xResult := DigInProcess(iRawValue,iHMIValue,xHMIOverride);
    The values of your function are of type BOOL. I guess this needs to be changed.
