hello, I’m not able to restore as factory my controller 1152. I was working with 2020.3 firmware and no external SD card. Today I installed PLCNextEngineer 2020.6 version on my laptop (¿error?). I migrated my project in progress and I made some modifications without a problem until I tried to test PLCNextBase 1.3.0 Libary. Firstly I called the service component program, I programed the logic described in https://s3.eu-central-1.amazonaws.com/plcnext-store-prod/doc/PLCnextBase_1_3_0_FBFun-20200712164920.pdf 4.2.1.2 section, and I restarted controller. Everything was ok and I could connect online like a normal situation. After that, I tried to test PBCL_SysNetwork_1 function block, and just making a download, the controller stopped to communicate, just boot led was flashing in red and D led was fixed orange color with no ping response. I’ve tried to: 1) restart the controller (no ping response to normal IP)
- restore the controller to defaults type 1 process many times (no ping to default IP 192.168.1.10)
- restore the controller to defaults type 2 process many times (no ping to default IP 192.168.1.10) In all cases boot led was flashing in red and D led was fixed orange color. What can I do?
