I have approx 30 x 2152 in the field (all running FW 2023.0.6). I have observed the 2152 intermittently loses the default gateway setting from it’s running config on some power cycles. So far, on the next power cycle the default gateway setting is initialised on the next power cycle.
After power cycle where comms via a VPN is lost, but LAN comms are still good:
I have looked at the change notes for FW 2024.0 LTS and in the known bugs/issues register and note this bug is not listed in either.
Network settings on initial configuration are set using PLCNext Engineer version 2024.0 LTS, and then not altered later on. Prior to identification of the bug, the offending PLC has just been power cycled to restore comms.
May I have some suggestions for a work around or a bug fix?
