Accessing PLC variables from HTML support file on webserver
Is it possible to access PLC variables from within a standard HTML file uploaded to the webserver as a support file?
Hi jnorris, you can use the REST API like also our own PLCnext HMI is using. Please read first the API description in the Info Center, also you will find already tons of posts in this forum. Just let us know if you’ve any questions… Take care, Frank
Thank you, I’m going to start researching that.
