Dear PLCnext Forum,
I am having trouble with an AXC F 1152 in combination with an AXL SE AO4 I 4-20 and an AXL SE AI4 I 4-20. I want to write and read directly the analoge values. This means: I want to write for example 15 mA and then read with the AXL SE AI4 I 4-20. I use both port 1 on the analog input and output. I connect the plus of the output to the plus of the input, same for the minus.
I can measure that something is happening, but I have the following problem: My variable that I use to write a value to the analog output is somehow overwritten.
See Figure 1, where I show how I compute the AO0_FBOut_TEST.
This seems to work well, but, now I go to the actual analog ouput: here I see the following:
Has someone experience with this or can someone help me to get into the right direction to solve this?
Thank you very much in advance!
