Hello, I’m currently trying to get my application running using the plcnext firmware. However, after a while I get the following error messages: 02.10.19 11:29:33.147 Arp.System.Acf.Internal.Sm.ProcessesController INFO - Process ‘LocalIoProcess’ started successfully.
02.10.19 11:39:33.821 Arp.System.Acf.Internal.Sm.ProcessesController ERROR - Could not start process ‘XConnectApp’.
02.10.19 11:39:33.827 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application ‘MainProcess’:
02.10.19 11:39:33.828 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type ‘Arp::System::Commons::InvalidOperationException’ was thrown
Could not start all processes
at: Arp::System::Acf::Internal::Sm::ProcessesController::StartProcesses()
at: Arp::System::Acf::Internal::Sm::SystemManager::SetupSystemSettings()
at: Arp::System::Acf::Internal::Sm::SystemManager::SetupSystem()
at: Arp::System::Acf::Internal::ApplicationBase::SetupSystem()
at: Arp::System::Acf::Internal::ApplicationBase::SetupBasicComponents(Arp::System::Acf::Internal::ApplicationSetupKind, Arp::System::Acf::Internal::ProcessKind)
at: Arp::System::Acf::Internal::MainApplicationBase::SetupInternal()
at: Arp::System::Acf::Internal::ApplicationBase::Setup(Arp::System::Commons::Diagnostics::Logging::LogLevel, char const*)
at: Arp::System::Acf::Internal::ApplicationBase::Main(int, char**, Arp::System::Commons::Diagnostics::Logging::LogLevel)
at: Arp.System.Application() [0x25fde]
at: Arp.System.Application() [0x2471e]
at: /lib/libc.so.6(__libc_start_main+0x114) [0xb69d4b40] I have verified that I’m able to run the application directly (without the ArpSystemModule_Load call), and it builds as expected using the ArpSystemModule_Load(). So as far as I can tell the application should be built correctly. Do you have any pointers on how to get the application to run, or how to get more information about why it couldn’t start the XConnectApp process? FYI: My includes and libs in the project is: INCLUDEPATH += \\
/opt/pxc/2019.3/sysroots/cortexa9t2hf-neon-pxc-linux-gnueabi/usr/include \\
/opt/pxc/2019.3/sysroots/cortexa9t2hf-neon-pxc-linux-gnueabi/usr/include/plcnext \\
/opt/pxc/2019.3/sysroots/cortexa9t2hf-neon-pxc-linux-gnueabi/usr/include/c++/7.3.0 \\
/opt/pxc/2019.3/sysroots/cortexa9t2hf-neon-pxc-linux-gnueabi/usr/include/c++/7.3.0/arm-pxc-linux-gnueabi \\ LIBS += -L/opt/pxc/2019.3/sysroots/cortexa9t2hf-neon-pxc-linux-gnueabi/usr/lib
LIBS += -lArp.Plc.AnsiC -lArp.Plc.Domain -lArp.Plc.Gds -lArp.Device.Interface -lArp.System.ModuleLib -lArp.System.Module -lArp.System.Rsc -lArp.System.Commons -lArp.System.Core -lArp.Services.NotificationLogger -lstdc++ -lpthread -lcppformat
