Ask for Installation of PLCnext Engineer
Hello Colleagues, I got question for Installation of PLCnext Engineer to PC. Execute the installer, but the installation does not complete. The progress bar stops at about 30%, and there is no change even after 1 hour. So, looking at the task manager, the operating rate of the hard disk is 100%. What are the possibilities? Software: PLCnext_Engineer_Setup_2020.0.1_LTS_(64bit) PC: Panasonic CF-LX6BDAQR Processor: Intel Core i5-7200U 2.5GHz 2.7GHz、RAM 8GB OS: Windows10 Pro 64bit 1909 Other Development Software : OMRON CX-One V4 .40.0005, Mitsubishi GX Works2 1.570U/GX Works3 1.058L, Microsoft Microsoft Visual Studio Code 1.39.1, Best Regards,
Hello, Please check that the PLCnext Engineer installer downloaded successfully, by checking the file size (as a rough guide) or by using CertUtil (to be sure) against the information on the download page. ~ Martin.
Hello Martin-san, Thank-you for your answer, I got information about installer and progress dialog, and try to get information of CertUtil later (Unfortunately, I can’t access download page of product… ) Best Regards,
PLCNext_Engineer_setup.pdf
Ah, OK. The SHA256 Checksum (for checking with CertUtil) is:
0f656daa0a19023070db58cb6f9e13b75cbebe3b5f4c529f269fcc31c2696ec8 The file size is listed as 467 MB, so that is there or thereabouts, based on your screenshot. So an incomplete download is unlikely to be the problem. I will discuss this internally and come back with a suggestion. ~ Martin.
additional information Hash is OK, and situation didn’t change after re-downloading and re-installing attached file is hash information, Best Regards,
hash_installer.pdf
Problem solved via email.
