AXC F 2152 - How many axis via PN interface?
Greetings, how are you?
I’d like to know if AXC F 2152 supports Profinet IRT, or any other protocols designed for improved response performance in motion control.
Also, if there is documentation about its motion control axis capabilities and limitations depending on the application (for example, this CPU supports up to 6 synchro axis, 1 master 5 slaves, for virtual gears or cams).
Any hints would be appreciated. Thanks for your time.
Best regards,
Hi, PLCnext Control devices do not support Profinet IRT, and they are not currently designed for motion control applications like the one you describe (sorry).
Hi, PLCnext Control devices do not support Profinet IRT, and they are not currently designed for motion control applications like the one you describe (sorry).</p>
Thank you for the info. And you don’t need to apologize, we are in front of a very powerful IIoT CPU anyway
