Axc f 2152 new firwmware problem
Dear Experts.
I just update my AXC F 2512 firmware upto version 2025.0.2.
After update, I can ping to PLC normally, but can’t go to its wbm.
Error 502 bad gateway happened.
what should I do?
Many thank
Try a Type 1 reset using the reset button on the front of the device, and the procedure in the User Manual:
Screenshot_20250627-123118.pngThen, take a look at the information in the Info Center about the changes that might need to be made to your application in order to make it work with firmware version 2025.0:
Application-relevant changes 2025 This documentation (also for download as a PDF file, b845ee9611647c5f87472624fa092fe3Hash value\n )\n specifies changes of the PLCnext Control firmware and SDK regarding the release 2025.0 that may be relevant to user-generated applications. For further technical support on this topic, you can contact the technical specialists in your local Phoenix Contact office, whose details you already have.
Forum - PLCnext Community PLCnext Technology from Phoenix Contact is a unique, open ecosystem for modern automation that is capable of meeting all the challenges of the IoT world. Dear Guys.
Thank many.
I tied and login ok.
