AXC F 2152 SD mass deploy on already used PLC
Hello I have follow the instructions (link here) to deploy PLCnext software with configured application and file from an existing implementation of another PLC but I have to load this on a already used PLC. The document specify to see Appendix 4 for this situation but It doesn’t exist. Any idee what need to be done ?
Fixed_Codesys_Gateway_on_PLCnext.pdf
I think that Makers Blog post was based on the PDF in this Github repository:
GitHub - plcnextusa/SDcardDeploy Contribute to plcnextusa/SDcardDeploy development by creating an account on GitHub. If the PLC has already been used, then a Type 1 reset will clear all the user files (apart from OCI images and other files stored outside the „upper“ directory).
You could check with the author by posting a comment under the Makers Blog post, or opening an issue on the Github project.
