Hey All,
We’re utilising an AXC F 2152 with .NET 6 running on it. Via a C++ application, running as the plcNext runtime, we start-up and have 2-way comms with the .NET 6 application to provide it will access to the real-time IO (write/read). We’re not utilising any other plcNext tasks etc (i.e. from plcNext Engineer).
Recently we’ve had what appears to be the Watchdog trigger. Even following a soft reset (i.e. sudo reboot), the watchdog appears to remain. The only way to fully reset the watchdog is to perform a full power down restart via the circuit breakers.
We’re wanting to understand:
1. How does the watchdog function (i.e. what could be triggering it)
2. Where the watchdog logs reason for it's triggering
3. What log files on the filesystem would contain pertinent information to track down the root cause?
It is worth noting that the logs under /var/log appear to clear every reboot as they’re written to RAM-backed storage?
Cheers,
Joseph
