A heads-up when only reading Axioline I/O’s I have come across a small but irritating bug when only reading values from Axioline modules. We are working on a logging system that only reads values from four AXL F IOL8 2H modules. I was wondering why the diagnostic LED on the AXL F IOL8 2H was blinking green. This would mean that there are communication issues with the master (AXC F 2152). But all values are presented in the program and correct. So I added an AXL F DI32/1 1F to see if the problem was related to the AXL F IOL8 2H - it wassn’t. After a short conversation with the Hotline, we came to the conclusion, that as long as no process data a written to at least one module in the Axioline bus, the diagnostic LED’s on the modules would indicated a fault by blinking green. In my case I have used on of the spare ports of one AXL F IOL8 2H as an output. I don’t actually have to set the output, just the connection to the process data was enough to solve the issue. If the PM for the PLC Next Engineer is reading this, please have a look. we already have one LED (BF-D) that is irritating, so we don’t need flashing LED’s. Peter
Hello Peter, this issue isn’t a reaction from PLC Next Engineer, it is defined in FW of AXL F IOL8 2H. I’ll forward your suggestion to the PM of AXL F IOL8 2H and inform you about the status of discussion. Best Regards Eduard
Hello Peter,
I forwarded this defect to the development and it will be fixed with FW 2019.9 for AXCF2152 (in September).
Best Regards
-Eduard-
Here is the conclusion to this issue:
* The behaviour is not a bug. It is by design, and documented in the user manuals for all Axioline I/O modules. * This behaviour is not related to PLCnext Engineer, or to the PLCnext runtime. It is a system property of all bus couplers and all controllers of the AXL F system. * When I asked about the likelihood that this behaviour will change in future, the response from the AXL IO team was: "It will not change."So it looks like the simple work-around (i.e. writing a value to an AXL output) is the only way to stop the LED from flashing in cases like this. ~ Martin.
Why don’t we see this in PCWorx if it is an Axioline “standard”?
