AXL F XT ETH not Profinet Master
Hello, When I use the AXL F XT ETH, it becomes the Profinet master port. Is there a way to change it to be the two onboard ports via Linux? I do not see any way to do this in Engineer.. Will this be added in the future? Thanks!
Hi Dan, this is planned as a long term feature, but for the next few release versions. Reg Frank
Frank, So there is currently no way to change the Profinet Master to the onboard ports when using the left extension? Thanks!
unfortunately not
