BalenaEngine daemon error
Error message: “Cannot connect to the balenaEngine daemon at unix:///var/run/balena-engine.sock. Is the balenaEngine daemon running?” when trying to execute any balena-engine command. Somebody fixed it? Balena daemon restarted by using “/etc/init.d/balena start” but the error keeps coming up. Thank you.
Hello, What PLC model do you have (e.g. AXC F 2152) What firmware version is installed on the PLC (e.g. 2021.0 LTS) How did you install balena-engine - using a script, or using the app in the PLCnext Store?
Hello Martin, AXC F 2152 with 2020.3.1 firmware, balena installed from github by command. Thank you.
please check out the 2020.3 tagged version of the Repository before you install docker.
https://github.com/PLCnext/Docker_GettingStarted/tree/FW_2020.3[
](GitHub - PLCnext/Docker_GettingStarted at FW_2020.3 · GitHub)
[git fetch --all --tags](https://github.com/PLCnext/Docker_GettingStarted/tree/FW_2020.3)
[git checkout tags/](https://github.com/PLCnext/Docker_GettingStarted/tree/FW_2020.3)FW_2020.3 branch
or
git clone [](https://github.com/PLCnext/Docker_GettingStarted.git "https://github.com/plcnext/docker_gettingstarted.git")<https://github.com/PLCnext/Docker_GettingStarted.git> --branch FW_2020.3
Hello Oliver, It works fine using this branch. Thank you.
