when logged in as root and trying to execute `visudo` I'm getting "Read-only file system". root@axcf3152:~# visudo visudo: /etc/sudoers: Read-only file system When I reboot the controller using the `reboot` command, the BOOT LED flashes red, but the controller does not turn on. The controller is equipped with an SD-Card and runs the firmware version: 2021.0.3 LTS When I disconnect the power supply and wait about a minute and connect it again, the controller boots correctly. When I now run `visudo` it works without a problem. This is happening for some time now, but seems to be random. I cannot narrow down, when it happens. Sometimes it works, sometimes it doesn't. Has anybody else encountered this bug or maybe it's a known issue? Cheers, Tom
