Hi Martin, I have a question similar to https://www.plcnext-community.net/index.php?option=com_easydiscuss&view;=post&id;=1512&Itemid;=224⟨=en I recently started my project over but using C# instead of C++ since we need the function block functionality. The problem is, this block needs to run (5 small) linux programs upon user command but as i understand this from the thread it can only be done from C++. FYI instead of calling external progs this was actually going to be done using a .NET library but it’s not compatible with eCLR since not every .NET function is implemented it turned out so this leaves us only that option. Of course I can’t go back to C++ but my question: is it much work to have the necessary classes implemented in the Phoenix framework? That way i can create a class for instance as described here: https://loune.net/2017/06/running-shell-bash-commands-in-net-core/ If i try this way now, I get: Connector.cs(78,35,78,39): error CS1110: Cannot define a new extension method because the compiler required type ‘System.Runtime.CompilerServices.ExtensionAttribute’ cannot be found. Are you missing a reference to System.Core.dll? I understand the concerns with execution time but I mean, what does phoenix care if a developer writes code that doesn’t work. It’s his/her responsibility, no? For my project i need to be able to: 1. execute 2 small linux binaries with params that have to be executed on command, they return immediately with just a statuscode. In worst case I could start them in a thread and asynchronously update the values in the ports using the returned values read from inside the thread. 12ms < 100ms so shouldnt be a prob: real 0m0.012s
user 0m0.006s
sys 0m0.001s 2. execute a program with params that immediately daemonizes (instant return): real 0m0.011s
user 0m0.001s
sys 0m0.008s 3. execute a program with params that starts a listener and from which the stdout should be mildly parsed in the C# block that called it. This ofcourse requires a thread so it doesn’t block the Esm. (Ofcourse, time the command doesnt make sense here). An other way is to change these programs so they serve on a local socket which i can then connect to from C# instead of starting a prog and catching the stdout but this is really not preferred and will cost too much time. So my point being, i really don’t see any problem here to launch shell commands from eCLR framework. Is there a way this can be easily implemented? Maybe by sending me some .dll/.so you use at Phoenix for internal use which is able to do all this so i can reference them from Visual Studio?
