Hello Community, I would like to create a program link from IEC61113-3 and C++ (Eclipse). Unfortunately I get the errors in the attachment when compiling and therefore I don’t see any ports that I can link. (When I put it into the library). I don’t know if I have initialized the variables correctly or where else the error can be. Can someone help me here. Thanks a lot
More Attachments
Hello plcnextstarter, as already discussed, the port attributes were not declared correctly. The port attributes must be defined for each individual variable and should not be in a single line. In the screenshot below, the error is outlined in red and the correct declaration outlined in blue. Best Regards Eduard
thank you very much
