C++ StaticString to String
Hi All! I’m reworking a the costum notification sender to be more flexible in the future. I’m trying to convert a StaticString<80> to a string type to fit in the „example payload“ of the example provided in GitHub.
But I’m probably missing something as I can’t succeed. Can someone give a hint? I guess I can convert a byte array to a string as well, is this the preferred way? Kind Regards Dries
Hello Dries,
please the following code:
//Definition in Component or Program header file:
pcoslib::IecString80 strValue;
//Initionalisation in C++ code:
this->strValue.SetCapacity(this->strValue.Capacity);
this->strValue.Remove(0);
//Convert the IecString80 to string:
string strNormValue((char*)strValue->Begin());
I’dont test it, but it should work.
Best Regards
Eduard
