C++ ThreadExample - program to instantiate missing in PLCnxt Engineer
i made a plcnext project based on the thread example with VScode using the plcncli tool for building.
I didn’t change anything to the source code from the example just copy/paste the code to the new created project.
Everything builds fine and i created the PLCnxt Engineering library with ‚plcncli deploy‘. I can import the plcnxt lib to PLCnxt Engineer. But all I see in the upper left drop down menu (Programmining → ThreadExample) is a DataType (ThreadExampleDataTypes) with nothing in it (empty editor showing line numbers). Also no program is shown under ‚programs‘ to instantiate under a task. I’m using the latest PLCnext Engineer 2025.0. Any ideas whats going wrong?
Thanks & Best regards,
Ralf
Hi Ralf,
is it in PLCnext Components & Programs?
image.pngBR
DivisionByZero
Hi DbZero, many thanks for the hint. Yes, indeed! it’s available under „Components & Programs“ and can be instantiate to a task. I can’t run the example now because i don’t have the hardware at hand - but will do as soon as im back in office.
BR Ralf
