Hello: I have defined the following Data Type: VFD_Motor : STRUCT
RUN : BOOL;
STOP : BOOL; FAULTED : BOOL;
SPEED : REAL;
END_STRUCT I now Created a Global Variable… Pump_Motor1 of Type VFD_Motor. I would like to assign Pump_Motor1.RUN to Digital Output00 (PLC Digital Output Card..axc-f-2152-1/dio-1/OUT00) Pump_Motor1.FAULT to Digital Input1 (PLC Digital Output Card..axc-f-2152-1/dio-1/IN00) Pump_Motor1.SPEED to Analog Output1 (PLC Analog Output Card.. axc-f-2152/ai-1/IN01) *** I tried to Tie Directly to the I/O Cards, but PLCNext Engineer does not allow the Pump_Motor1.xxxx to used on any Physical I/O Point. I cannot use PORTs, as I have both Inputs and Outputs - there is no ability to use combined Inputs and Outputs on a single Structure. Is there anyway to accomplish this Directly ? Are there plans to include this fucntionality in the near future ? Thanks, Peter
