I am currently trying to build a project with the 2019.6.3 32 bit toolchain (pxc-glibc-i686-axcf2152-image-sdk-cortexa9t2hf-neon-toolchain-2019.6.sh) and I encounter the following error:
/opt/pxc/2019.6/sysroots/x86_64-pokysdk-linux/usr/libexec/arm-pxc-linux-gnueabi/gcc/arm-pxc-linux-gnueabi/8.2.0/real-ld: cannot find -lstdc++fs
Is the stdc++fs not supported by this version of toolchain?
Hello I made a mistake, problem occurs on x64 toolchain: pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-toolchain-2019.6.sh, not on x86. Best regards, Mihai
Hello Mihai, the library is basically available for the GCC we use. However, since no component in our system has a dependency on the named library, it can not be found in the SDK (normal Yocto mechanism). If possible, please give me information about the customer project. I will check if it is possible to create a requirement for the next SDK, so that libraray will be avalable for the next versions. Thanks & Best Regards Eduard
