Hello everyone,
I am working on establishing communication between an Invertek VFD and the AXC F 2152 PLC using the AXL F CAN module and the CAN Basic library. My current code is designed to send a start command to the VFD.
I have followed the examples provided in the library documentation, but I cannot figure out how to handle writing to specific CANopen indices (e.g., 2000h or 2001h for the VFD).
The issue I’m facing is that the CAN_CO_PDO_Write block from the library only asks for the Node ID and COB ID, but it does not allow me to specify an Index or Subindex for the data I want to write.
According to the VFD manual, SDOs (Service Data Objects) are only used for changing parameters, so they are not applicable for my current use case
Additionally, I have some doubts about the software configuration for the AXL F CAN module in PLCnext Engineer. I have connected the CAN_H, CAN_L, and GND lines physically, but I want to confirm if there are specific settings or mappings required in the software to ensure the module is properly initialized and functioning as expected.
Does anyone have suggestions or experience handling this situation?
Thank you in advance for your help!
