is there a way to change the hostname of the controller?
It is mentioned in this post: https://www.plcnext-community.net/forum/#/discussion/1788/dns-hostname-via-online-parameters
The name of the DHCP client cannot be changed in PLCnext Engineer or in the Web-Based Management. The same requirement that Frank mentioned in that other conversation is still open, but we cannot say when that feature will be available. In the mean time, the DHCP client name can be set manually in the /etc/hostname file if necessary.
