CILG0001 - Update from PLCnextBase 1.6.2 to PLCnextBase 1.6.3
I’m trying to update the PLCnextBase library in my project from version 1.6.2 to 1.6.3 and get the CILG0001 Error. I’m currently using the PLCnext Engineer 2023.0.5 and don’t really want to upgrade to a new PLCnext Engineer Version although I want to use the new PLCnextBase library.
Is this issue already known, are there any infos on that?
Thanks in advance
Philipp
Hello Philipp,
The problem should be solved by closing the PnE instance and then reopening it or closing the project and reopening it.
Before that you would have to replace the lib and save the project.
Best regards
Luis
