can I use MTP while coding in Codesys?
And can I import a C++ library into Codesys like in PLCnext Engineer?
Thanks
Thanks
If no one in the PLCnext Community can help with this question, then someone at Codesys will certainly be able to help. The answer should be the same regardless of the platform that Codesys is running on.
