Hello, regarding of the ongoing active developments of PLCnext Eng and FW of Controlers, the question arises as to how it works backward Compatibility. CPU with FW 2019.x I can
to use in all 2019.x versions of Engineer limited to old features. To use the new functionality, the Engineer version is the same or higher. What is the plan to do it in the future?
HW as such, I suppose it will be manufactured unchanged for many years. But if I will use one or two years later the Engineer 2021.09 and will try to connect with the FW 2019.6 PLC, can I upload the project from the PLC (if there are some sources) without the need to change the Engineer version? Or I will need to upgrade FW PLC? Will 100% program functionality be maintained? what is the idea? Thanks, Roman
