Hi, We are trying to compile open CV with PLCnext SDK (FW 2019) and PLCnext technology C++ tool chain (Revision 2019.0 LTS HF1). After creating a new C++ project in eclipse , selected AXC F 2152 program from the shared library. When going to edit the build configuration in the properties window of the newly created project, we can’t find the Çross G++ compiler’tab under C/C++ Build > Settings. (screen shot attached) The same is working, if i am using the SDK of the previous firmware. What could be the possible reasons?
Hello Vishal, we switched with FW 2019. to a CMAKE build system.
This way we are able to integrate projects in any IDE. If you want to add dependencies like Open CV you will have to add it to the CMakeLists.txt file in your project. https://www.plcnext-community.net/index.php?option=com_easydiscuss&view;=post&id;=1837&Itemid;=221⟨=en
kind regards,
