Connect my PLCNext 2152 to Azure IoT Hub - Issues with libraries
Hello everyone, I want to connect my PLCNext 2152 to Azure IoT Hub. I am working with IIoT and IT libraries. I tested the IT library, uploading a example code into the PLC and it worked fine. Now I wanted to integrate with IIoT library and I got two different issues. First one relies on using the variable ip_sock, because there is not a variable type called IPC_UDT_IP_SOCKET in the project. I think that is cause with the management of libraries. (Picture test1). Second, I am using an example program from IT library adding the IIoT library, but now I am having an error code CILG0001. I checked all variables and there are not any IN or OUT variable declared in the code. How can I solve all these issues? Thanks a lot in advance for your help. Best regards, Cristian
Hi Cristian, As advised by email, the solution to the first problem is to include the IP_Com_10 library in your project a second time, separately to the IT_Library. If you are still experiencing the second problem, please let us know. (ref: #221892)
