Contact and Coil Label Wrapping
I have imported LD programs, and some of the contact and coil label wrap properly to a second line, and some are truncated with “…” at the end. I can’t find a way to get them all to wrap. Is there a setting for this. Not easily and quickly knowing the name makes programming and debug difficult.
We haven’t been able to reproduce this with PLCnext Engineer version 2022.6.
Can you perhaps list the steps we can follow to reproduce this problem?
Alternatively, if you are able to send us a project that demonstrates this problem, it can then be investigated.
Yes, this is repeatable in 2022.6. Who should I send the XML file to?
You should have an email in your inbox (or possibly your spam folder) with instructions on how to send a PLCnext Engineer project that demonstrates this problem.
The results of the investigation can be posted here, so others can see the answer.
Here is the answer from the PLCnext Engineer support team:
we created a improvement item in the development for this case.It is planned to implement in one of the further [PLCnext Engineer] versionsFor now you can only remedy this manually by copying and pasting the abbreviated variables.
