For a project I’m working on I would like to be able to control the UR5e cobot using the AXC F 2152, the cobot has a realtime protocol called RTDE which already has C++ libraries that seem very capable of doing what I need.
Which steps can I take to implement these libraries so that I can use them within PLCnext engineer?
Dear Yael,
Please contact support@phoenixcontact.nl directly, I will be able to help a bit easier that way. If and when we find a solution we will append it here in the community for other members to see.
With kind regards,
Damian Bombeeck
Technical Consultant
IMA Technical Sales Support The Netherlands
Dear
I’ve created a C++ PLCnext project using the RTDE libary. Unfortunately the community won’t let me share the files. I have attached a general how-to on cross compiling 3rd party libraries.
Manual_CrossCompilation.docxIn general the steps to use 3rd party libraries are:
Download the source files from github (https://github.com/UniversalRobots/Universal_Robots_Client_Libraryimage.pngimage.png
- Create a buildscript to cross-compile the source files which creates a shared object file for the PLCnext
- Create a PLCnext C++ project and add the includes as well as the shared object file to the CMake file and the „external“ folder
- Add the desired includes to the header file of the project
- You can now use the functions from the library.
