Could not connect to the controller
Good afternoon. I’m an electrical engineering student and I’m learning to use PLCnext engineering. I have a PLCnext kit with an AXC F 2152 controller. After configuring the in/output modules and writing a small program with external variables connected to the physical outputs and inputs ( AXL DI8/1 DO8/1 1H). When I try to connect with the controller, it gives the following error in the online log „Connection failed, no response from the controller“ error code: MSG_ONL0156 and also „Could not connect to the controller“ error code: MSG_ONL0047. Can someone please help?
Have you completed the „IP Configuration“ step of the Quick Start procedure described here?
Quickstart: Overview on Engineering Steps ');\n mywindow.document.close(); \n mywindow.focus();\n setTimeout(function () {\n mywindow.print();\n mywindow.close();\n }, 1000)\n return true;\n}\r\n\r\n\r\n The IP address of the PLC must be set to a spare address in the same subnet as the Ethernet adapter (on the PC) that is connected to the PLC.
