Hi, Is it possible to create an Any structure in C# from an input or output variable? The reason behind this is, that my function block inherits a base class consists of several function with Any as arguments (Because the function should be used by multiple inherited classes but with different datatypes) public class Base { ... public bool function1(ref Any data) { ... } } [FunctionBlock] public class Derived : Base { [Input] public int Value1; [Output] public bool Value2; ... public void __Process() { Any intValue = new Any(&Value1;, sizeof(Value1), Eclr.TypeInfo.GetHandleFromType(Value1.GetType())); base.function1(intValue ); Any boolValue = new Any(&Value2;, sizeof(Value2), Eclr.TypeInfo.GetHandleFromType(Value2.GetType())); base.function1(boolValue ); } }
hello, you can create ANY Inputs or outputs using the ANY_NUM attribute. CSharpExamples/PLCnext_CSharpExamples/02_Any/Any.md at master · PLCnext/CSharpExamples · GitHub kind regards, Oliver.
