Create app for two controllers
Hello, I have created a app that runs on AXC F 2152 and AXC F 1152. I have generate the app file for 2152 and other for 1152. In app_info.json file, I configure the target parameter to “AXC F 2152” ou AXC F 1152". How can I configure the app_info.json file to generate the app file compatible with the two controllers in the sametime ? How can I define two controller in target parameter ? Thank you, Sidnei Marcondes
Hi Sidnei, I am afraid that what you want to do is currently not possible. This means that, for every different PLC type that you want to support - AXC F 1152, AXC F 2152, AXC F 3152, RFC 4072S, etc - you need to create a different app in the PLCnext Store (note that this does not apply to Library -type apps). This issue has been already been raised with the Store team, and I will ask for an update on when a better solution may be available. ~ Martin. (ref: 00133154)
Hi Sidnei, Here is more information from the Store team:
The store (and the WBM) only allows the installation of an app on the devices for which the app was developed.
In order for the store to perform this check, the developer must specify the supported device in the app-info.json.
Currently only one device can be specified in app_info.json, because the WBM can only perform one check.
In the future it will be possible to specify multiple devices* in app_info.json. For this purpose the firmware must be adapted.
*An app file can only be valid for one architecture at a time. (e.g. armhf or intel)
There is currently no information available on the timing of this future plan. ~ Martin.
