we have an own web application running on a EPC 1502 under a custom port, that we want to display on the Display Port.
Is it possible to set the port we are using as the default page for the integrated web browser?
I have found out, that the browser binary references a file called settings.ini, that does not seem to exist. Could creating that file and inserting some definitions be used to change the default page?
Hello ingfu,
currently this is not possible at all.
However this exact feature will be integrated in the next firmware-release next month!
After the upcoming update, you will be able to output any local URL or local port and set it as your homescreen.
These configurations are then available inside the WBM in a user-friendly manner.
The release is planned for Mid-April.
Best regards
Daniel
Hello ingfu,<\/p>currently this is not possible at all. <\/p>However this exact feature will be integrated in the next firmware-release next month!<\/p>After the upcoming update, you will be able to output any local URL or local port and set it as your homescreen. <\/p>These configurations are then available inside the WBM in a user-friendly manner.<\/p>The release is planned for Mid-April. <\/p>Best regards<\/p>Daniel<\/p>
Thanks for the reply! I am looking forward for the firmware release.
