DataLogger issue
    In my project there are 40 Real points and 13 Boolean points that are logging. When the project is loaded, the logging is working good. However, when the log folder was deleted by an user initialization program last Friday, xError for DL_File_2 became TRUE. After a weekend of running, the xActive for DL_AnyTypeFB_2, DL_AnyReal_2 and DL_Logger_2 became FALSE.
    The log folder was recreated by the initialization program last Friday but the xACtive will not be TRUE any more no matter how I played with xActivate inputs for these blocks today.  Thus, the xError is always TRUE for DL_FIle_2 since its xActivate is connected to xActive of DL_Logger_2
    Can anyone give a help for the dataLogger?
Thanks
Jason
Hello Jason,
to analyze this issue I need more Error details, please send me the Output.log File to my EMail address:  emuenz@phoenixcontact.com
Thanks & BR
Eduard
Hello Jason,
I tested this use case and can reproduce the behavoir, I assume this case is not planned and tested. Generally the library developer expects, that the defined folder will be not deleted during the operation.
I think it is a request for Library Developer, in PLCnext Store you can contact developer directly.
May be it is possible to implement the needed handling in the next library version or he can send you a possible workaround.
BR Eduard
