Date and Time
I try to set the NTP server to UK server in the Date And Time tab. But this error has occurred
Can I get help?
I try to change the NTP server in the Date And Time tab.
No error occurred on AXCF 2152 but EPC1502. (img)
Can I get help?
Hello Park,
yes this is unfortunately known and already fixed in FW-Version 2023.0.6. Please update the FW used.
image.pngBR Eduard
Hello Park,</p>yes this is unfortunately known and already fixed in FW-Version 2023.0.6. Please update the FW used.</p>[https://forum.plcnext-community.net/uploads/A1DXU9OOZQQC/image.png</a></p>BR Eduard</p>
Thank you for your help.
So the minimum version of synchronizing time to the ntp server of EPC1502 is 2023.0.6 LTS?
So what is the minimum version of AXC F 2152?
This problem was unique to EPC devices and should not occur in AXC F 2152 devices.
This problem was unique to EPC devices and should not occur in AXC F 2152 devices.</p>
So the minimum version of synchronizing time to the ntp server of EPC1502 is 2023.0.6 LTS?Yes, that’s correct. The problem was identified in EPC firmware version 2023.0.5 LTS and fixed in version 2023.0.6 LTS.
So the minimum version of synchronizing time to the ntp server of EPC1502 is 2023.0.6 LTS?</p>Yes, that’s correct. The problem was identified in EPC firmware version 2023.0.5 LTS and fixed in version 2023.0.6 LTS.</p>
Thanks for your help Martin.
I can’t test epc1522 now because I don’t have a device. Is there a minimum version for epc1522 to set up an ntp server?
Yes, the EPC 1502 and the EPC 1522 both use the same firmware „platform“, so the above discussion applies to both products.
