Hi, i am currently working on changing the controller in an existing PLCnext project. We started the project with the AXCF2152 and are now switching to the AXCF3152. But i cannnot figure out how to configure the network ports. I want to use port X2 for Profinet and port X1 (or X3) for everything else. But everytime i assign the PLCnext to my project, the interface for the project is automatically set to X2. Now i have to be connected to the profinet network (which is seperated from everything else) to connect to the plc using PLCnext Engineer. I can ping port X1 and connect to the wbm using the IP adress of port X1. Is there any way to change the default programming network interface? Best regards
Hi Simons, you’re right, the default programming port is always the port with the PN controller, which is in case of the AXC F 3152 Port 2, but you can chance this in the cockpit view. After the project is saved, the selected port stays default for the project. Hope that helped, Frank
Yes that solved the problem! Thank you very much!
