Disable Continuous Compilation
Is there anyway to disable the continuous compile in PLCnext Engineer? If I make a new variable…compile. If I type a single character while writing a function block…compile. If I move an HMI object one pixel to the left…compile. It slows down my productivity significantly. Yes computer, I am aware that the line I just typed isn’t going to work, I paused for a moment to decide whether to use < or <= for this statement. I really don’t need a bunch of red squiggly lines and another compile to tell me. If the compile was fast, it wouldn’t be quite so annoying, but it is slow. Yes, 2-5 seconds is slow when it does it constantly. Please, make it optional. It may be helpful if you are a novice with IEC 61131-3, but it is unnecessarily cumbersome to my workflow. Thank you.
Hello I have the same issue. I want to deactivated continuous compilation and so far I have not found any solution for it. Thank you ahead for any help and support.
Dear customers, the background compile and syntax check cannot be switched off due to several reasons.
Internally the system needs the created data from the compile, for example to have the new created variable in the data list or being able to show existant instances. The process is placed on another CPU core since PLCnext Engineer 2019. So on one core you do editing your project and on the other core the compile process runs. Of course, a multicore system is required for this. This means that the background compiling no longer blocks your editing experience.
Special is the usage on virtual machines, please take care that multiple cores are assigend to the VM and enough RAM is usable.
We suggest a multicore system with 8 GByte RAM and Windows 10 / 64 Bit. Since version 2019.0 we put a lot of effort to the perfromance of the PLCnext Engineer. You can see and feel it already if you compare PC WORX 7
with the latest version of PLCnext Engineer 2019.3 The most sigificant performance improvement will be available with version 2019.6. Please excuse that we could not satisfied with the overall perfromance of the PLCnext Engineer today, but I think, our improvements will show you that we are working in the correct direction. We are continuosly working to improve the performance. In case of further questions or improvement proposals, dont hesitate to contact us directly. Best regards,
Oliver Warneke
Hello Oliver, Thank you for your comment and help.
Oliver, thank you for your response. I understand the motivation behind having all new data checked and ready for use throughout the program, but feel that it could be better optimized. Not every action needs a compile. Variable creation: Yes, New function block added: Yes, Add a task: Yes, Move a button 5 pixels to the left: No, Add comments: No. Set an initial value, No. Adjust FBD spacing, No. I’d love to see the structured text editor area not compile at all until either the user commands it, the project is saved, or the user changes to a different editor window. That way we’re not racing the compiler with the text entry. At present, if you pause too long while typing, it starts to compile. In regards to the system requirements, I am running Windows 10 Pro 64, 8GB RAM, SSD, quad-core i5 and yet have tremendous slow downs if any other program is open, especially web browsers. I have disabled syncing for Dropbox and OneDrive, disabled anti-virus, set Priority to Realtime, Affinity to all CPU cores and still see large peaks in processor consumption and long pauses, ~10 seconds, between actions. The longest pauses are in the HMI editor, especially when working with symbols with multiple user parameters. Are there software or background processes known to interfere with PLC Next Engineer? Can PLC Next Engineer take advantage of the GPU? What specs does your team run for your computers. Do I need to upgrade to +16GB RAM, PCIe SSD, and a Xeon? Thank you for your support. Josh
Hello Josh, of course we are working to improve the performance of the system.
I hope you will be able to see significant improvements in this regard in the comming release 2019.6. kind regards,
Oliver, I apologize if I come off sounding upset, I have a tendency to get worked up when I’m excited about things. To be honest I work better with computers and electricity than I do people. Perhaps a better way to state the second half would be: I currently meet the minimum requirements to run the software, what would an optimal laptop spec look like? I will be more patient with the process and am very much looking forward to the future of the platform. Here is the project I am working on. I have connected the PLC Next to a Garmin Marine Multi-Function Display. I have installed the package manager and the Avahi mDNS service on the Linux side of the AXCF to provide ZeroConf network configuration. System provides monitoring and control for Main Propulsion engines and Auxiliary Power Generation engines. The Syncro page is the interface for my Wiper synchronization control. https://photos.app.goo.gl/bMUHtgibdesizoTh7 Video of the wiper control. Originally built on an ILC 191 and now migrated to the PLC Next. https://youtu.be/vHqz-aIp0g4 Sincerely, Josh
