Dear colleagues, I would like to know how to install Easy RSA, it is for a project I am developing and I need to create the certificates to work with PLCnext as a server. Is there any procedure? Which version do you recommend to install?
Hello lbonillayanez, I can’t recommend a particular version, I do not know this project exactly. Generally it should work: https://github.com/OpenVPN/easy-rsa Because it appears to be just a shell script. In general, I would recommend not operating a CA on the controller, because the private keys of the Root-CA are also located on the controller …
Instead, you can operate easy RSA on a separate computer. Best Regards Eduard
