Eclipse C++ library targets
Hello, I’ve installed the Eclipse IDE plug-in. I can created a pcwlx file and I am able to see it in PLCnext Engineer. However, I do get the error it’s not compatible with axcf2151. I’ve both newest (2019.9) SDK and firmware. If I go to the properties of the C++ program, the target selected is: AXCF2152,19.9.0.23151 How can I fix this? Arne
Hello Arne, which PLCnext Engineer Version are your using?
Are you also using a AXC F 2152.9 Template?
Try replacing the template again.
                                               1. on the right hand side search for the "axc f 2152 2019.9 " template
                                               2. copy
                                               3. Paste it on the left side. or right-click replace
Kind regards,
I typed it in the quick acces search bar, but there are no results, not even on “axc”, or didnt you mean in eclipse IDE? However, I am using a template and I got a component and program file (both header and cpp). After building the project I get the project.pcwlx file. In that binary is also the folder AXCF2152_19.9.0.23151. Also the Engineer software is up-to-date, 2019.9. When building, the Command Line Tool shows: "Succesfully built the project name for target AXCF2152,19.9.0.23151. Arne
Hey, no i am talking about the PLCnext Engineer.
You will not be able to include a 19.9 Library into a Engineer Project with a 19.0 Template because 19.0 does not support all the features of 19.9 that you might be using…
The Instructions I mention are for replacing templates inside PLCnext Engnineer…
That makes sense. Is it possible to change a 2019.6 project to a 2019.9 then?
Yes see this link
