Eclipse IDE Error PLCnext 2020.0
I tried to create a library for PLCnext Engineer using Eclipse IDE. Operating system Windows 10, did everything as described in the videos https://youtu.be/UNbNv7eBHPE and https://youtu.be/IUGSZzuzm-c But when compiling, the eclipse produces errors that can be seen in the screenshot and Eclipse_Console_Error.pdf Eclipse IDE Version: 2021-03 (4.19.0) PLCnext - PLCnCLI_SDK_2020.0_Windows_AXC_F_2152.zip I’d appreciate your help. Best regards, Maksym Chuhaiev
Hello Maksym, are you still online, we can start a remote session, if it is possible. For remote support please download and run the FastViewer application: http://fv.phoenixcontact.com/client/fastclient.exe Best Regards Eduard
Hello Eduard, please tell me the session number. Best Regards, Maksym
Hello Maksym, the new Session Number is: 44603 If you have MS Teams/Skype then we can try to start session with audio channel (In this case I need your e-mail).
Hello Eduard, I’m sorry, but this is our working pc and it doesn’t have a microfone and speakers. Can I connect in the same way as last time?
Ok the new Session Number is: 49640
My email max448911@gmail.com
Hello Maksym, the used Eclipse version 2021-03 is not tested, I suspect the error is here. Please install the Eclipse Version 2020-12. Please send me a short feedback, if the failure is resolved. Thanks & Best Regards Eduard
