Edit ClientNow on HMI
Hey, I was wondering if there is a easy solution for the DateTime on the HMI, but then without some parts. For example the ‘#LTD’ and the (micro)seconds. I’ve found that the substring or substr functions can get parts of the string easily. The ClientNow in the HMI is from the LDATE_AND_TIME type, so it’s not workable as a string. How can I only show parts of the Clientnow? Should I convert it somehow? Or is there a way to declare a new variable with the current time or date? I can’t find another variable in the PLCNext which gets it and updates.. Thanks, Arne
Good Morning Arne, hmm, there are many options, but maybe the following will already do it: [list] []Use the FB RTC_S. It returns the sysytem time as a string according to the IEC 61131 notation. Via “MID” string operation you can take only the parts you like. []Or use the RTC int variables and bind them to single text fields for the current date time. [/list] Which way you choose, depends on your preferences, but should be both fairly simple and easy to implement… BR, Frank
