I have the following requirements: - Simple HMI for a machine ( ✓ AXC F 2152 with eHMI) - HMI users need to log in ( ✓ AXC F 2152 with eHMI) - HMI users must be authenticated against a Windows Active Directory server. ( ??? ) Can a PLCnext guru tell me if this final requirement is currently possible and if not (which I suspect) - are there any plans to make this possible, or else any tips on how I can easily roll my own AD authentication with eHMI?
- HMI users need to log in ( ✓ AXC F 2152 with eHMI) Currently with AXC F 2152 (firmware 1.0.0.250) the eHMI user can not (needs not) log in. In 2018 we want to bind eHMI to the PLCnext User Manager. > - HMI users must be authenticated against a Windows Active Directory server. ( ??? ) In the future we intend to combine the PLCnext User Manager with LDAP. This would also enable a combination with Active Directory Server.
Hi Martin, If you are feeling really adventurous , you might (but it again… you probably shouldn’t), cross-compile your own nginx-binary, and combine it with this module https://github.com/kvspb/nginx-auth-ldap. and swap it with the on-target binary. This would enable you to have ldap-auth from within nging’s config files, where you place certain URI’s behind ldap auth. You should at least compile with the current options:
root@axcf2152:~# nginx -V > nginx version: nginx/1.10.1 > built with OpenSSL 1.0.2j 26 Sep 2016 > TLS SNI support enabled > configure arguments: --crossbuild=Linux:arm --with-endian=big --with-int=4 --with-long=4 --with-long-long=8 --with-ptr-size=4 > --with-sig-atomic-t=4 --with-size-t=4 --with-off-t=4 --with-time-t=4 --with-sys-nerr=132 > --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log > --error-log-path=/var/log/nginx/error.log --pid-path=/run/nginx/nginx.pid > --prefix=/usr --with-http_ssl_module --with-http_gzip_static_module > >But i highly advice against it, as it might break more than you bargained for.
