I have a 24Vcc encoder , conected to a module AXL F CNT2 INC2 1F. I cant see any count or change on the data list of the module. whem the enconder move the lights of the module still off . I conect the channel A, B and Z and use the 24Vcc source from CN1. If I use the encoder in the counter module its work .
is necessary to active some input or byte to active the module?
Thanks
Hello Diego,
Please try the following settings:
Modulo = 1000dec
1LimitValOut = 0dec
2LimitValOut = 100dec
LimitValOut must not be equal to or greater than modulo.
I am writing the code for encoder AXL SE INC1 SYM on PLC Next. I have struggled with the input variable set up for the encoder. How can I get the position values for low word and high word ? Thanks a lot.
Chapter.
