EPC 1502 run the node - red
Hello lixlin, can you please give me more information what you are trying to do or where a problem occures? I guess you are trying to start Node-RED on the EPC 1502? Node-RED is started within the start-up of the EPC, so you don’t need to start it manually. 1. Connect to your EPC (via X2:LAN - default IP: 192.168.2.10) 2. Open up a webbrowser (e.g. Chrome) and open up the URL: 192.168.2.10/cockpit 3. Once the Cockpit opens up, you can start Node-RED from here If you need further help, please let me know. Daniel
Thank you for your help. If there are any new questions, I will ask you
