Hi AppStore experts, after I edit and save a draft, I return to Software Products and get the message:
Oops! Something went wrong!
Status Code: 500.
I want to publish a library, but I can’t get into Software Products anymore, even restarting my computer doesn’t work.
Hi, I have an even worse error. When I try to open my profile I get the same error.
Hi , thanks for your report.
The issue you have with entering your profile is not related to the PLCnext Store. We are already working on a solution.
The original issue reported by liqunzhao is already solved in direct contact with the user.
Hi [@suprunchuk</a>, thanks for your report.</p>[@suprunchuk</a>The issue you have with entering your profile is not related to the PLCnext Store. We are already working on a solution.</p>The original issue reported by liqunzhao is already solved in direct contact with the user.</p>
Okay, I’m waiting for the problem to be fixed.
I also have problems with my profile for a long time, and I can’t open my profile and change my profile photo.
