When i try to import a new library, i get an error that the version is not correct. I downloaded the library .msi file from the phoenix contact site, under plcnext engineer. Do I need to use an older version and where can i find it then? Or am I trying to use the wrong files? Best regards Joël
Hey, Analog Technology 5 is an older version. For 2019.0 you need version 6, which can be found in PLCnext Store https://www.plcnextstore.com/#/7
Jarrko is correct, the PLCnext Store is the best place to get all libraries for PLCnext Engineer. Older versions of PC Worx Engineer are still available for download from our website, which is why these older libraries are also still available. I will ask the product manager to make it clear on the website which PLCnext Engineer version each library is compatible with. - Martin.
Thank you guys for the quick responses. I’ll try looking for the other libraries I need, now that I know where to find the correct one’s. ![]()
