Hi Forum,
We’re currently trying to convert our PLCNext Engineer project from version 2021 to version 2022. One of our projects converted succesfully, but unfortunately, the other conversion produced an error.
It looks like there is some data in the Log file, but we’re not sure how to proceed from here. Any help is greatly appreciated, thanks in advance!
Best regards,
Gijs Bruining
13:56:44,5224 | Ade.Shell Error: 0 : Exception during loading project: Ade.Project.AdeSolutionException: External client canceled opening the solution. —> Ade.Project.Repository.OpenSolutionException: Failed to open C:\Users\Gijs\Repos\swim_vcu\swim_vcu.pcwef —> Ade.IO.VirtualFileSystemFileSystemEntryNotFoundException: The entry was not found.
at Ade.Shell.Internal.Persistence.ProjectConversionService.Convert(ISolutionFileSystem solutionFileSystem, Dictionary2 from, Func2 buildSolution)
at Ade.Shell.Internal.Persistence.ProjectConversionService.Convert(ISolutionFileSystem solutionFileSystem, Dictionary2 from, Func2 buildSolution, Boolean isTempLibConversion)
at _b954712b0400479b8ce65e957fe92bd2.xkydv.xvxeb(OpenSolutionFileSystemParameters auw, ISolutionFileSystem& auw, OpenSolutionSettings auw, String auw, String auw, Dictionary2 auw) at _b954712b0400479b8ce65e957fe92bd2.xkydv.adaof.aeyuz() at Ade.Diagnostics.ApplicationEventSource.RunAction[T](String category, String actionName, Func1 action)
at _b954712b0400479b8ce65e957fe92bd2.xkydv.xvxeb(OpeningStorageEventArgs auv)
at _b954712b0400479b8ce65e957fe92bd2.xkydv.OnBaseOpeningStorage(Object sender, OpeningStorageEventArgs e)
at _b954712b0400479b8ce65e957fe92bd2.xkydq.OnBaseOpeningStorage(Object sender, OpeningStorageEventArgs e)
at _99a0836fa922453f8daef4110eeadc67.iefna.mjrng.dyaee(Object qz, FileSystemCreatingEventArgs qz)
at _99a0836fa922453f8daef4110eeadc67.iefkh.bmsox(OpenSolutionFileSystemParameters db)
at _99a0836fa922453f8daef4110eeadc67.iefkh.OpenExistingCore(ContainerMode mode, ContainerAccess access, OpenSolutionOptions options)
-– End of inner exception stack trace —
at _99a0836fa922453f8daef4110eeadc67.iefmb.OpenExisting(ContainerMode mode, ContainerAccess access, OpenSolutionOptions options)
at _99a0836fa922453f8daef4110eeadc67.iefkn.GetProjectCore(Uri uri, ContainerMode mode, ContainerAccess access, ProjectStorageOptions options, Boolean isPrimaryProject, OpenSolutionOptions openSolutionOptions)
at _99a0836fa922453f8daef4110eeadc67.iefme.GetProject(Uri uri, ContainerMode mode, ContainerAccess access, ProjectStorageOptions parameters, Boolean isPrimaryProject, OpenSolutionOptions options)
at _99a0836fa922453f8daef4110eeadc67.iefkl.oyxrh(ContainerAccess ec, OpenSolutionOptions ec)
at _99a0836fa922453f8daef4110eeadc67.iefkn.GetSolution(Uri uri, ContainerMode mode, ContainerAccess access, SolutionStorageOptions options, OpenSolutionOptions openSolutionOptions)
at 99a0836fa922453f8daef4110eeadc67.iefjt.GetSolution(Uri uri, ContainerMode mode, ContainerAccess access, SolutionStorageOptions options, OpenSolutionOptions openSolutionOptions)
at 988eaea86bc74c59b224c3c9b169c8d7.vfwlz.bhwhz(Uri km)
at Ade.Domain.Workspace.Workspace.Open(Uri uri, OpenSolutionOptions options, Nullable1 cancellationToken, IProgress1 progress)
-– End of stack trace from previous location where exception was thrown —
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Reactive.Stubs.<>c.<.cctor>b__2_1(Exception ex) in //Rx.NET/Source/src/System.Reactive/Internal/Stubs.cs:line 16
at System.Reactive.ObserverBase1.OnError(Exception error) in /_/Rx.NET/Source/src/System.Reactive/ObserverBase.cs:line 61 at System.Reactive.Subjects.Subject1.OnError(Exception error) in //Rx.NET/Source/src/System.Reactive/Subjects/Subject.cs:line 122
at System.Reactive.Subjects.Subject1.OnError(Exception error) in /_/Rx.NET/Source/src/System.Reactive/Subjects/Subject.cs:line 122 at Ade.Domain.Workspace.Workspace.Open(Uri uri, OpenSolutionOptions options, Nullable1 cancellationToken, IProgress1 progress) at _99a0836fa922453f8daef4110eeadc67.iefna.wvfge(String qm, OpenSolutionSettings qm, ISolutionFileSystem qm) \--- End of inner exception stack trace --- at _99a0836fa922453f8daef4110eeadc67.iefna.wvfge(String qm, OpenSolutionSettings qm, ISolutionFileSystem qm) at _b954712b0400479b8ce65e957fe92bd2.xkydp.Open(String fileName, OpenSolutionSettings settings) at _b954712b0400479b8ce65e957fe92bd2.xkydl.Open(String fileName, OpenSolutionSettings settings) at _b954712b0400479b8ce65e957fe92bd2.xkydk.Open(String fileName, OpenSolutionSettings settings) at _b954712b0400479b8ce65e957fe92bd2.xkydo.Open(String fileName, OpenSolutionSettings settings) at _b954712b0400479b8ce65e957fe92bd2.xkydj.Open(String fileName, OpenSolutionSettings settings) at _b954712b0400479b8ce65e957fe92bd2.xkydn.Open(String fileName, OpenSolutionSettings settings) at Ade.Project.SolutionManager.OpenSolution(String fileName, OpenSolutionSettings settings) at Ade.Shell.ShellMediator.edsmm(String wf, OpenSolutionSettings wf, Action2 wf)
